Mon problème
The reason I had to repair the camera was because in the instructional video to fix the camera they did not say that the two terminals on the camera were glued down so when I pulled the camera off the terminal were ripped off the camera.
Ma solution
It went well besides the fact that the top corners of the screen were sticking out a little more than the rest of the screen. I don't know if there are slots the top part of the screen go into any holes or not so I'm going to look at it again today.
Mon conseil
Make sure you take the camera out very slowly and use a razor blade to slide under the terminals on the camera to get rid of glue and then you should be fine.
0 commentaires
