fix of iphone 5s.And fix of imac a1224 emc nr 2210
leohobb -
Mon problème
the iphone had a broken glass display was working.The imac mod a1224 emc nr 2210 stopped working for a friend in the music aranger and musican.powersuply was the problem i found out with help fom your informative site and videos.worked with electroniks for 30 years.
Ma solution
The iphone 5s i have bougth a display from a site that usualy deliver topp parts for brands that alow 3 party selling parts for their products.Iphone displays is a diferent matter.The new display was not funtion properly.The broken work fine.So i contakted ifixit and got a real good servise.Orderd new display kit from them and few minutes later it worked like it should.i could feal the kvality in conektors hwen pressing them in plase the clikk sound and feal told me that conetors are good quality.One thing is the same with those to display kit . The pressure pads on top of the conektor are missing in this kit to.orginaly its a thin firm foam pad on the conetors to hold conector pressed down when you skrew the small metal bessel over.I made my own with bisykle tire punctering patch thath i used a sisser on the edge thath is thin like the pads.The girl who owns the iphone is i happy girl with a good replasement display.Best quality conetors yet.The imac a1224 emc nr 2210 change of power supply.i folowed the advise form ifixit and went for a powersupply that looks diferent.same conetors and form factor.so it fited rigth in.It is cooler than the other model like my orginal supply. anyway i drilled 10 .4,2mm hole where there was most heat.cleaned out the black paper/metalfoil ressidue and rounded the holes so they loked okei outside and innside.put it together now its cool under pressure.i have pictures of both rep and wil upload the best representative pictures.
Mon conseil
Advise.be sure that your new display have pressure pads on the connectors.ifikxit has the best conectors.
0 commentaires
