Mon problème
Power seemed to be running down faster than before.
Ma solution
Took me about 10 minutes. The Pentalope driver included with the kit fit perfectly and the replacement went without a hitch, although it does take a bit of careful prying to get the old battery out. The included pry tool worked like a charm and should come in handy for other projects.
Mon conseil
My advice is to attach the battery plug before pressing the battery into place. The small, ribbon connector requires a slight bend and this will happen automatically if the plug is attached first and the battery pressed in second. Also, have a clean work area with lots of light and a place to put the tiny screws. Otherwise, no tools needed except what comes in the kit.
0 commentaires
