Mon problème
Unable to turn off the the screen and dock connector was mangled.
Ma solution
Followed the guides and things went ok, but I damaged the wifi antenna opening it... and the cable to the digitalizer pulled loose (left side of screen went dead) when I laid the glass flat next to it. So ordered both of those and finished up in about 20 minutes.
Mon conseil
When opening separate the wifi antenna from the glue on the digitalizer or you will replace it. Set a cup or something next to it and lean the digitalizer standing up at 90 degrees verse laying flat... no stress on it that way.
0 commentaires
