Mon problème
Soaking wet and I made the mistake of calling it to help locate it , found in washer pulled it out took it apart dried it out but no flash on camera and a couple other issues , Ordered mother board, Came on time and worked as described
Ma solution
Only one minor problem , After all together I found it was hard locked to AT&T , fixed in a couple minutes and all is right with the world again Thanks AAAAAAAAA+
Mon conseil
Don't bother with the rice trick , Pull phone apart use a hair drier and a tooth brush
0 commentaires
