Nexus 7 (2013) USB board replacement
Mon problème
My Nexus would no longer charge or sync with my PC
Ma solution
Simple, just carefully remove the back from the Nexus, remove 6 screws holding the Usb board and unclip and remove all the cables attached replace the board and reverse the process. Took 5 Min. and now its perfect again.
Mon conseil
The hardest part is removing the back take it slow and gently work your way all around the case. (and remember Youtube is your Friend)
0 commentaires
