New battery can fix a bad trackpad.
Very difficult
Mon problème
The old battery didn't have much life left in it, but that was actually the smaller problem. The battery had gotten to the point where it had swollen so much that it was pushing up on the bottom of the track pad made clicking impossible. I had to enable some of the multi-touch features just to be able to click and drag and drop!
Ma solution
Very easy. Nothing was glued in this model, and the bottom screws are easy too remove. Too easy in fact, which is why I bought a screw set since 2/3s of my screws had fallen out and been lost. Good to have my bottom cover on securely and fresh loctite on the threads.
Mon conseil
The walk-through calls out the spudger, but you really don't need it to bend the sticker over the left battery screw back.
Also, a great time to clean your fans if you haven't done so in a while.
0 commentaires
