Aller au contenu principal
« Retour à Toutes les histoires
MacBook Pro 13" Unibody (Early 2011/Late 2011/Mid 2012) Airport/Bluetooth Cable
Eric Bodenhausen -
MacBook Pro 13" Unibody Early 2011
MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement
Easy
Mon problème
I was having issues with my Wifi Dropping a lot. After researching I found out that there was an issue with the Airport/Bluetooth Cable.... so rather then paying Apple to diagnose that I needed a new Airport/Bluetooth Cable and charge me an arm and a leg to repair it... i figure I would try this out first... for $30 and some change... why not!!
Ma solution
So I watched the video and read the step by step directions that iFixit had posted on how to change out the Airport/Bluetooth Cable and it took me less then 20 minutes and I was up and running... it has been about 2 weeks since I replaced the cable and everything seems to be working GREAT!!!
Mon conseil
Watch the video and follow the step by step instructions that iFixit provides and you will have NO issues
Image Spudger
Spudger
$3.99
Image Phillips #00 Screwdriver
$6.99
Image Phillips #000 Screwdriver
$8.99
Image MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable
$24.99
Ajouter un commentaire
