Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
« Retour à Toutes les histoires
Easy repair - Samsung Tablet connector
markap6 -
Samsung Galaxy Note 8.0
Samsung Galaxy Note 8.0 USB Port Replacement
30 minutes
Moderate
Mon problème
The inner connector in the mini-USB port is easily damaged (I much prefer the Apple design). That was the case on this tablet - a proper connection could not be made to recharge the tablet, rendering it useless.
Ma solution
The hardest part of this repair was separating the case without any fractures. I went slowly, starting at the point for holding the stylus, used a plastic spudge for most of it and a very thin knife blade in one area near the top. Once the case was open, the rest of the repair took at most, 10 minutes.
Mon conseil
Go slow when opening the case, use the plastic spudge for lifting the connectors, be sure to reseat them firmly.
Image Galaxy Note 8.0 (Wi-Fi Only) Charging Port
$16.99
Ajouter un commentaire
