Mon problème
My battery was pretty old, and usually discharges in the middle of the day. So I decided that it's time to replace it!)
Ma solution
It was quite easy
Mon conseil
Notice! (for proper NFC working)
When you snap back the back cover of the phone, you have to start with the upper middle clips (firstly push in the center above letter S), in this case your NFC will be working fine.
I give you links on the battery and the tools that I used in the description below the video. Hope it will be helpful.
0 commentaires
