Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
« Retour à Toutes les histoires
Howling cooling fan.
clinton -
MacBook Pro 15" Core Duo Model A1150
MacBook Pro 15" Core Duo Model A1150 Left Fan Replacement
Difficult
Mon problème
Left fan on a 1,1 15" MBP was making a awful racket, worn out bearing, had to go. Couldn't stand to use the thing it was making such a fuss.
Ma solution
A cinch - whole job took about 20 minutes start to finish. In a MBP 15" the left fan is pretty easy to get to and get out of the computer. When the new one from iFixit arrived, I put it right in and reassembled - no more racket!
Mon conseil
Carefully look over the instructions on how to disconnect the several cables that have to be moved out of the way to replace the fan - especially the copper-colored ribbon cable that lays across the main body of the fan; it attaches to the MLB via an ultra-miniature, verrry delicate 'clamp' style connector. If you try to unfasten it the wrong way you will break it. That would be... very bad.
Image MacBook Pro 15" (Model A1150) Left Fan
$29.99
Ajouter un commentaire
