Macbook Motherboard replacement
orvis -
Mon problème
The system had overheated because it did not go to sleep with the lid closed. That cooked the motherboard and made the system flakey.
Ma solution
The repair went OK.
Mon conseil
Mention that the heat sinks have been removed and you will need to move them from the old motherboard. You will need heat sink grease to make good thermal contact.
0 commentaires
