Mon problème
The battery would drain very quickly and it always neeeded to be plugged in.
Ma solution
It was easy. The instructions were very good. The battery resolved my issue. I'm so glad I made the decision to replace my battery over buying a new phone!!!
Mon conseil
I used a small pocket knife to pry the screen off the case. It was thinner and once I was in between the screen and case I used a twist motion and it simply popped out. I felt the tool provided was just enough thick I had to really work to get it between the screen and case.
Be careful by the home button on the inside. There are 2 prongs that make connection for the home button to work. I smashed one down accidently and it took some work to get that corrected.
The inside screws are small. A magnifying glass came in handy. When removing the battery, pry along the edge of the case, NOT anywhere from the inside.
0 commentaires
