MacBook Pro Unibody Early 2010 Trackpad replacement
Mon problème
The trackpad was damaged by a dying battery which expanded and pushed up against the trackpad.
Ma solution
The replacement went well, although the guide was for a 2011 macBook, so slightly different
Mon conseil
The trackpad for the 2010 MacBook uses a little yoke to hold the trackpad in place. This doesn't show up in the guide, but the little aluminum yoke is included with the parts. Look at the way the yoke is attached to your old trackpad and put the new yoke on the new trackpad in the same way.
2 commentaires
Yes you can!
cliffdean88 - Réponse
Definitley doable.
