Mon problème
Overheating problems when under heavier loads.
Ma solution
It went pretty smoothly. The only struggle came when I was separating the keyboard and monitor/base from each other. It required a lot more force than I had expected.
Mon conseil
When separating the keyboard and monitor/base, definitely attempt using less force and tools (as I did for forty minutes), but if it still doesn't separate by then, definitely use a bit more force while also being careful.
0 commentaires
