« Retour à Toutes les histoires
Easy and well worth it!
rsimoes -
iPhone 5s
How to replace the battery in your iPhone 5s
20 minutes
Moderate
Mon problème
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
Ma solution
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
Mon conseil
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specially with the one near the outside of the case, it rips very easily, and then you have to carefully heat and pry the battery off. I did this repair on two phones and both ripped and had to be pried off, but I think next time I'll know how to prevent it.
Image P2 Pentalobe Screwdriver iPhone
$8.99
