Mon problème
Battery not lasting as long as it used to on a charge
Ma solution
Replacement went great except for almost ripping one of the adhesive strips under the battery. Lost the pull tab but was able to use the tweezers from the repair kit to grab the end of the strip and gently pull it out from under the old battery
Mon conseil
Didn't need to completely remove the display. I gently rubber-banded it to the original box as seen in step 9 of the repair guide and didn't need to remove it. Just don't move the whole thing around too much to avoid putting strain on the display cables
0 commentaires
