Aller au contenu principal
« Retour à Toutes les histoires
iPhone 6 Plus Battery Replacement
Edward Arnold -
iPhone 6 Plus
2 heures
Moderate
Mon problème
Battery health had dropped below %60 and was not lasting as long as it should.
Ma solution
Repair went well. I followed repair guide from iFixit and used some videos from youtube to get a different perspective. Had a glitch on the screen after reconnecting screen, but followed video instructions for trouble shooting and disconnected the screen digitizer cables and reconnected them to make sure connection was correct. Everything worked great after that.
Mon conseil
I would make sure that when you reconnect the small display digitizer cables, that you follow the repair guide instruction carefully and push down only on the left & right corners and try to avoid pressing on middle of the cable.
Image Magnetic Project Mat
$19.95
0 commentaires
Ajouter un commentaire
