Mon problème
Battery no longer holding a daily charge when used for calls only
Ma solution
Repair was straightforward, however the battery was not a drop in replacement for the OEM battery. The ribbon was flat, requiring the consumer to make the bends in the ribbon cable potentially damaging the ribbon cable and the battery.
Mon conseil
ifixit should raise the bar on the quality of product supplied and specify a drop-in replacement battery from the Chinese supplier with the OEM bends in the connector cable.
0 commentaires
