Mon problème
The battery was at 84% capacity & affecting how i used it.
Ma solution
The problem was the battery hold down strips. The first one came out with no problem. The second one broke & left no tail to grad hold of. I tried the dental floss with little success. I modified an old motel room access card by cutting off the magnetic strip. That helped but also used a heating pad. The tweezers in your kit helped the most in getting under the battery & lifting it up but was getting concerned because the battery was getting bent slightly.
The new battery tab was also a problem in that it wasn’t bent at 90 degrees to battery. It was more like 120 degrees & i had to bend it back to make it work. Getting the tab to stay put in the connector also took some adjustment.
Mon conseil
I could’ve used a better tool to get under the old battery & your pro kit looks like it has it. Too late now.
Un commentaire
Your guide & online videos helped a lot! Thank you…
William Hansen - Réponse
