Aller au contenu principal
« Retour à Toutes les histoires
S6 battery replacement
carlosriosness -
Samsung Galaxy S6
Samsung Galaxy S6 Battery Replacement
25 minutes
Moderate
Mon problème
the battery was dying within a few hours.
Ma solution
smoothly.
Mon conseil
i bought the tape kit from ifixit. its good for 2 corners, so i added a little bit more 2 sided tape. its not as good quality, but it should be better then nothng.
you will also want a microfiber and alcohol so you can clean the back panel off since it will have glue residue on it.
i did buy the microwavable pad, it worked perfectly, never needed to turn on my heat gun.
i used the heat pad on it for a minute, then the i slack to pull it apart just enough to run the halberd spudger into a section of it. i then used an opening pick into the area the spudger loosened.
i repeated the spudger and pick all the way around. i had to reheat the pad 2 more times as i did this and move it around.
Image Halberd Spudger
Halberd Spudger
$2.99
0 commentaires
Ajouter un commentaire
