13 inch 2011 speaker replacement
Mon problème
The subwoofer stopped working,I think that it might have been my fault-I played music for about 3 hours with VLC .The sound was amplified at 200%,there was no distortion,but it killed it.
Ma solution
It took me about an hour to replace both.The screws are very small,an you have to be carefull with cable routing,when you put it back together.Also when I detached the speaker,the metalic plate underneath it moved-you need to hold it in place.
It works just as good as the original.Nice replacement
Mon conseil
magnetic screwdriver helps a lot with the small screws
0 commentaires
