Mon problème
Airport card dropped signal
Ma solution
Challenging because of the small screws.
Mon conseil
Install the left-hand screw on the Airport card and then connect the antenna connections. Don't install the right-hand screw until you've made the right-hand antenna connection, because that leaves you much more room to work.
0 commentaires
