Aller au contenu principal
« Retour à Toutes les histoires
laptop got heat during charging,stop charging,rust in the contacts in MagSafe
Den -
MacBook Pro 13" Retina Display Late 2012
MacBook Pro 13" Retina Display Late 2012 MagSafe DC-In Board Replacement
Moderate
Mon problème
in repair centre it coast twice more and takes two months. I don't know peoples who were satisfied such repair
Ma solution
today i fixed my macbook pro. it took around 2 hours. With your guide and instruments it was very easy.but i got 2 item superfluous.First it is plastic pull tab of the microphone ribbon cable.Second it is one contact from microphone cable socket.It was very hard to pull off this cable and i pulled off this contact together with cable
Mon conseil
Thank you very much for your guides and tools ! it was very helpful.
i would like add thermal paste(and guide for this) to list of parts(in start of guide), on step 11 it was very late. now i assembled macbook without it. have i to buy it and add ?
Philips #00 screwdriver is much bigger then the same screw in step 10. This screwdriver not fit screw. i had to find smaller screwdriver
And once more thank you for your help !
Image MacBook Pro 13" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board
$29.99
Image Spudger
Spudger
$3.99
Image T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Image Phillips #00 Screwdriver
$5.49
Image Tweezers
Image T5 Torx Screwdriver
T5 Torx Screwdriver
$5.49
Image P5 Pentalobe Screwdriver Retina MacBook Pro and Air
$5.99
Image TR7 Torx Security Screwdriver
$5.99
0 commentaires
Ajouter un commentaire
