Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. (TC) PlayStation Teardown, (TC) PlayStation Teardown: étape 1, image 1 de 1
    • Flip the unit upside down to access the six screws on the bottom.
    • Remove the six screws indicated with a Phillips-head screwdriver. All the screws are of the same length.
  2. (TC) PlayStation Teardown: étape 2, image 1 de 1
    • Turn the unit back over, and pull the top half up and away from the device.
  3. (TC) PlayStation Teardown: étape 3, image 1 de 1
    • Unplug the laser assembly's power cable and ribbon cable from the main board.
    • Remove the two screws on the memory card/controller port, disconnect the ribbon cable, and lift it out of the case.
  4. (TC) PlayStation Teardown: étape 4, image 1 de 2 (TC) PlayStation Teardown: étape 4, image 2 de 2
    • To remove the power supply, disconnect the cable and remove the two screws, then lift it out of the case.
  5. (TC) PlayStation Teardown: étape 5, image 1 de 2 (TC) PlayStation Teardown: étape 5, image 2 de 2
    • Remove the 3 screws from the shield.
  6. (TC) PlayStation Teardown: étape 6, image 1 de 2 (TC) PlayStation Teardown: étape 6, image 2 de 2
    • Remove the 5 Phillips screws.
    • You can now lift the main board out of the case.
  7. (TC) PlayStation Teardown: étape 7, image 1 de 2 (TC) PlayStation Teardown: étape 7, image 2 de 2
    • Lift the RF shield out of the case.
  8. (TC) PlayStation Teardown: étape 8, image 1 de 2 (TC) PlayStation Teardown: étape 8, image 2 de 2
    • Reinstall the RF shield by dropping it in and lining up the slots and tabs.
  9. (TC) PlayStation Teardown: étape 9, image 1 de 2 (TC) PlayStation Teardown: étape 9, image 2 de 2
    • Replace the main board. Only install the screws indicated in red.
  10. (TC) PlayStation Teardown: étape 10, image 1 de 1
    • Replace the top shield, and secure with the 3 screws indicated.
    • Reinstall the memory card / controller module. Connect the ribbon cable and replace the 2 screws.
  11. (TC) PlayStation Teardown: étape 11, image 1 de 1
    • Align the optical drive assembly with the three pegs.
    • Reconnect the power and data cables for the optical drive.
  12. (TC) PlayStation Teardown: étape 12, image 1 de 1
    • Slide the cover on the system in the same way you took it off and replace the black screws indicated.
  13. (TC) PlayStation Teardown: étape 13, image 1 de 1
    • Plug in the console and turn it on.
    • Thanks for looking at my teardown!
Nick
Membre depuis le 11/10/09
88 809 Réputation
49 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 25
Total : 43,029
