Introduction
This is a basic teardown of the HTC Rezound showing the various components.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre HTC Rezound, utilisez notre manuel de réparation.
Remove rear cover using little notch located at bottom of phone Remove rear cover using little notch located at bottom of phone Remove rear cover using little notch located at bottom of phone
  • Remove rear cover using little notch located at bottom of phone
Ajouter un commentaire
Remove 1620 mAh battery
  • Remove 1620 mAh battery
  • Remove SD card
  • Phone comes with 16 GB SD card
Remove (6) Torx T7 screws You may have to remove VOID sticker from one of the screws
  • Remove (6) Torx T7 screws
  • You may have to remove VOID sticker from one of the screws
Use opener tool to carefully pry cover off Volume and power buttons are located in cover so be careful not to lose them Speaker is located inside back cover
  • Use opener tool to carefully pry cover off
  • Volume and power buttons are located in cover so be careful not to lose them
  • Speaker is located inside back cover
    • Main Camera
    • Headphone jack
    • Vibration motor
Carefully unplug board Carefully remove camera cover, slowly peeling off tape to reuse Remove and unplug vibration motor
  • Carefully unplug board
  • Carefully remove camera cover, slowly peeling off tape to reuse
  • Remove and unplug vibration motor
Remove (2) Phillips heads screws (one is shown, the other is on the left lower side) Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly. Main camera connection & front camera
  • Remove (2) Phillips heads screws (one is shown, the other is on the left lower side)
  • Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly.
  • Main camera connection & front camera
Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed. Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
  • Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
  • For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
Codyhatch24
Membre depuis le 26/12/2013
191 Réputation
1 tutoriel rédigé
Équipe
Android Alliance Membre de l'équipe Android Alliance
Community
70 membres
436 tutoriels rédigés
If there's anything I can add to help make this more clear cut and easy to follow let me know as this is my first attempt at a guide.
Codyhatch24 - Réponse
My rezound glass is cracked . It still operates fine but I would like to replace the glass. I ordered a glass from Amazon but it has a connection tail that I don't understand how to install?
Lee Ferguson -
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 15
Total : 3,589
