This product teardown will require pliers, a Phillips head screwdriver, a Y-head screwdriver, and a flathead screwdriver. Certain components will require some prying, so be prepared. You will also need some grip paste available, as some screws are placed very tightly in their spots.
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Home Essentials Sandwich Press, utilisez notre manuel de réparation.
Unscrew the heating element wires from the hot plates using a PH1 screwdriver. The screws are 5 mm long.
Remove the heating elements using a Phillips head screwdriver, and put this screwdriver under the heating elements.
Removing the heating elements requires some more pressure because they are put in with a tight snap fit. The heating element will also deform when removed.
