Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Hyundai H-150, utilisez notre manuel de réparation.
  1. Hyundai H-150 Teardown, Hyundai H-150 Teardown: étape 1, image 1 de 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: étape 1, image 2 de 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: étape 1, image 3 de 3
    • We'll start with a preview of the phone. Front, back and side view are shown here.
  2. Hyundai H-150 Teardown: étape 2, image 1 de 3 Hyundai H-150 Teardown: étape 2, image 2 de 3 Hyundai H-150 Teardown: étape 2, image 3 de 3
    • The battery is removed easily. Just pull down the part from the back and the battery goes out.
  3. Hyundai H-150 Teardown: étape 3, image 1 de 3 Hyundai H-150 Teardown: étape 3, image 2 de 3 Hyundai H-150 Teardown: étape 3, image 3 de 3
    • After the battery is out, we're presented with a plastic cover with all the phone's information (Model No., Serial No etc)
    • Notice the 4 Philips screw-heads in each of the four corners. Those need to go off.
    • After unscrewing, you might notice that the cover doesn't easily go off. Four clips are holding the back cover onto the front cover.
    • Use a Spudger and unclip the sides of the cover. It shouldn't put up much resistance
  4. Hyundai H-150 Teardown: étape 4, image 1 de 3 Hyundai H-150 Teardown: étape 4, image 2 de 3 Hyundai H-150 Teardown: étape 4, image 3 de 3
    • Once the back cover is off, one can see the motherboard and a strange metal part on the top of the phone. This serves as an antenna booster, but also to protect the board.
  5. Hyundai H-150 Teardown: étape 5, image 1 de 3 Hyundai H-150 Teardown: étape 5, image 2 de 3 Hyundai H-150 Teardown: étape 5, image 3 de 3
    • See that hole in the shield? That Has a screw in it. And yes, it needs to leave.
    • After removing the screw from the shield, it can be lifted from the board easily, revealing another board beneath it.
  6. Hyundai H-150 Teardown: étape 6, image 1 de 3 Hyundai H-150 Teardown: étape 6, image 2 de 3 Hyundai H-150 Teardown: étape 6, image 3 de 3
    • It seems that this secondary board is held onto the main board by a board connector.
    • Pull the board gently and you'll notice it comes out rather fast.
  7. Hyundai H-150 Teardown: étape 7, image 1 de 3 Hyundai H-150 Teardown: étape 7, image 2 de 3 Hyundai H-150 Teardown: étape 7, image 3 de 3
    • By this stage, the board simply comes out of the front body, exposing the keyboard and its associated membrane.
    • On the board we encounter the ringer(upper left), the headphone/handsfree input(under the ringer) and the LCD (which is sadly sticked on the board, as is the keypad membrane)
    • On the case we encounter the microphone (lowest part of the phone case), the loudspeaker (the highest part of the phone case)
  8. Hyundai H-150 Teardown: étape 8, image 1 de 2 Hyundai H-150 Teardown: étape 8, image 2 de 2
    • That concludes the teardown for now.
Nicolay
Membre depuis le 04/08/13
371 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 15
Total : 832
