Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Innovative Technology iPod Docking Station IT-5022WHT, utilisez notre manuel de réparation.
  1. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: étape 1, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: étape 1, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Overview: étape 1, image 3 de 3
    • Before Teardown
    • Condition: Well used
    • Noted issue: static sound when adjusting volume.
  2. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: étape 2, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: étape 2, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Opening the Back Panel: étape 2, image 3 de 3
    • Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main.
    • Remove the 9 phillips screws.
  3. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: étape 3, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: étape 3, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Look at the Guts: étape 3, image 3 de 3
    • Speakers
    • Display & Logic Board
    • Top panel buttons board
    • Audio Jacks
    • DC Power Connector
    • Antenna
  4. Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: étape 4, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: étape 4, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, DC Power Board and Audio Jacks: étape 4, image 3 de 3
    • DC Power Board
    • Audio Jacks board
    • Remove the two screws
    • The boards are glued in, so carefully pry them out of the casing.
  5. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: étape 5, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: étape 5, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Antenna Removal: étape 5, image 3 de 3
    • You can pull the antenna apart without opening the entire case. This is helpful if just part of the antenna is bent.
    • For full removal, remove the screw on the bottom of the box labeled "antenna", and slide the antenna out the top.
    • Coax cable connects the antenna to the tuning circuit on the upper PCB.
  6. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: étape 6, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: étape 6, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Speakers: étape 6, image 3 de 3
    • Remove three screws holding the three mounting brackets for each speaker.
    • Use a blade to remove the glue holding the speaker wires in.
    • Carefully pry the speakers off their mounting points because they are glued in.
  7. Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: étape 7, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: étape 7, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, LCD Panel and Logic Board: étape 7, image 3 de 3
    • Removing the LCD Panel and motherboard.
  8. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: étape 8, image 1 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: étape 8, image 2 de 3 Innovative Technology iPod Docking Station IT-5022WHT Teardown, Top Panel Buttons Board: étape 8, image 3 de 3
    • Remove 6 screws
    • Pry out the panel by hand
    • Careful of the volume and tuning nobs when pulling the board down
    • Check out that coil
  9. Innovative Technology iPod Docking Station IT-5022WHT Teardown, Exploded View: étape 9, image 1 de 1
    • Overall this product was pretty easy to take apart.
    • The internals were pretty easy to identify based on their location and appearance.
    • One drawback was that the speakers were glued in. The glue prevents rattling, but makes the speakers harder to get to. Some glue should be used when replacing the speakers.
    • 8/10 repairability
Dylan
Membre depuis le 11/24/14
66 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 940
