Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Jump Starter Power Station, utilisez notre manuel de réparation.
  1. Jump Starter Power Station Teardown, Jump Starter Power Station Teardown: étape 1, image 1 de 3 Jump Starter Power Station Teardown, Jump Starter Power Station Teardown: étape 1, image 2 de 3 Jump Starter Power Station Teardown, Jump Starter Power Station Teardown: étape 1, image 3 de 3
    • Power Station Jump Starter
    • Model PS1100
    • The bad battery could be replaced to restore it to full functionality.
  2. Jump Starter Power Station Teardown: étape 2, image 1 de 3 Jump Starter Power Station Teardown: étape 2, image 2 de 3 Jump Starter Power Station Teardown: étape 2, image 3 de 3
    • Opening it up reveals the Lead battery, AC/DC converter, 12V DC input, switch, back of circuit board, back of light.
    • Additional bells and whistles are sometimes added (lights, switches, compressors, power jacks, etc.) Some have AC power jacks which require a DC/AC converter which is more expensive than an AD/DC converter.
  3. Jump Starter Power Station Teardown: étape 3, image 1 de 2 Jump Starter Power Station Teardown: étape 3, image 2 de 2
    • The battery to the left is the culprit of the dead power supply. A jump starter is nothing more than a small car battery with some wires.
    • Any 12V battery with the same dimensions should work as a replacement
    • This is a Lead 12V 17AmpHours battery made by Pilot battery Co. Ltd.
    • Model PL17-12
  4. Jump Starter Power Station Teardown: étape 4, image 1 de 2 Jump Starter Power Station Teardown: étape 4, image 2 de 2
    • Both power inputs. AC/DC converter and DC 12V input.
    • The designers of this jump starter simply purchased an aftermarket AC/DC adapter and built it in.
    • The adapter has an input of 120V (typical outlet voltage) and an output of 15V (perfect for charging a 12V battery).
    • Left - DC Power Jack, Right - Thermal Relay for safety and protection
  5. Jump Starter Power Station Teardown: étape 5, image 1 de 3 Jump Starter Power Station Teardown: étape 5, image 2 de 3 Jump Starter Power Station Teardown: étape 5, image 3 de 3
    • Circuit board with your typical LEDs, Resistors, Transistors (black half circles), IC chips (long black), Capacitors (disks and cyliders), buttons (right middle) Power Rectifier (left middle square), Diodes (small black, bar on one side), Piezo Speaker (large and round, bottom)
    • Light with 5 LED's
    • Big Switch to handle 12V
  6. Jump Starter Power Station Teardown: étape 6, image 1 de 2 Jump Starter Power Station Teardown: étape 6, image 2 de 2
    • The back module is the compressor. It will still function normally by application of a 12v power supply.
    • I did not disassemble the compressor. I will bolt a plexiglass cover over the top and solder a 12v car adapter to run it as an emergency compressor
    • I have a walk through on recycling the compressor on instructables.com
Brent Olsen
Membre depuis le 07/26/11
411 Réputation
1 tutoriel rédigé
25 commentaires
where can i find more information on the circuit? plan to add a switch to my jumpstarter to either charge the internal battery or an external battery...
would that 700mA handle a 65Ah battery if i simply attach a device like that to that slightly bigger battery?
gcb - Réponse
I have one of these that the ac adapter has come loose from the main board. is there a possibility that you could post a photo of exactly where the adapter solders onto the main board?
Phillip Duke - Réponse
can I use a 12V 18Amp
pjfz80 - Réponse
To charge the battery? The back of the unit will say what the "input" should be.
Brent Olsen -
helpful article any chance on getting the dimension of the battery I do not see PL17-12 but many like it. the dimension would be helpful
Edward Ginsberg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 32
30 derniers jours : 107
Total : 124,637
