Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre LG VX8350 Repair, utilisez notre manuel de réparation.
Locate the horizontal grip located on the back cover of the phone. Slide the back cover down and off of the phone.
  • Locate the horizontal grip located on the back cover of the phone.
  • Slide the back cover down and off of the phone.
Ajouter un commentaire
Insert a plastic opening tool into the battery release point located above the battery. Pull outwards in order to release the battery.
  • Insert a plastic opening tool into the battery release point located above the battery.
  • Pull outwards in order to release the battery.
Locate the 5 screws holding the body of the phone together. The top screw will have a plastic cover, remove it using tweezers. Using a Philips head screwdriver, twist counterclockwise to remove the screws.
  • Locate the 5 screws holding the body of the phone together.
  • The top screw will have a plastic cover, remove it using tweezers.
  • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
  • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
Lift the back cover starting at the bottom of the phone. Lift the back cover starting at the bottom of the phone.
  • Lift the back cover starting at the bottom of the phone.
Remove the back cover completely from the phone. Remove the back cover completely from the phone.
  • Remove the back cover completely from the phone.
Locate the clamp at bottom right side of the Circuit Board.
  • Locate the clamp at bottom right side of the Circuit Board.
  • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
Locate the ribbon connecting the circuit board to the phone display. Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
  • Locate the ribbon connecting the circuit board to the phone display.
  • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
  • Remove the circuit board
Lift the keyboard and remove it from the phone. Lift the keyboard and remove it from the phone.
  • Lift the keyboard and remove it from the phone.
Locate the two rubber circles covering the screws. Remove the rubber covers using tweezers. Using the Phillips head screwdriver, unscrew and remove the two screws.
  • Locate the two rubber circles covering the screws.
  • Remove the rubber covers using tweezers.
  • Using the Phillips head screwdriver, unscrew and remove the two screws.
Close the phone and gently pull outwards from the bottom left portion of the phone cover. Take care not to do this with too much force, as it could crack the cover. Completely remove the cover from the phone.
  • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
  • Take care not to do this with too much force, as it could crack the cover.
  • Completely remove the cover from the phone.
You have now performed a complete teardown of the LG VX8350.
  • You have now performed a complete teardown of the LG VX8350.
Jonathan Flowers
Membre depuis le 18/10/2013
607 Réputation
11 tutoriels rédigés
Équipe
Clemson, Team 14-7, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 membres
15 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 1,264
