Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Linksys WRT54G, utilisez notre manuel de réparation.
  1. Linksys WRT54G Teardown, Get your Linksys: étape 1, image 1 de 2 Linksys WRT54G Teardown, Get your Linksys: étape 1, image 2 de 2
    • The Linksys WRT54G series is a series of Wi-Fi gateways manufactured by Linksys, a subsidiary of Cisco Systems.
  2. Linksys WRT54G Teardown, Antenna Removal: étape 2, image 1 de 2 Linksys WRT54G Teardown, Antenna Removal: étape 2, image 2 de 2
    • Let's begin with the teardown! First, unscrew the antennas from the back of the router and set them aside.
  3. Linksys WRT54G Teardown, Front Panel Removal: étape 3, image 1 de 3 Linksys WRT54G Teardown, Front Panel Removal: étape 3, image 2 de 3 Linksys WRT54G Teardown, Front Panel Removal: étape 3, image 3 de 3
    • Lets get into the internals! First, flip the unit over and insert a small flat-head screwdriver in between the warranty sticker and the front panel and gently pry it open.
    • Beware! It may take some effort to pry the panel off. Also, be careful not to damage the motherboard, like I did.
    • This will certainly void your warranty from 2002, in case you wanted to know.
  4. Linksys WRT54G Teardown, Remove Top Panel: étape 4, image 1 de 3 Linksys WRT54G Teardown, Remove Top Panel: étape 4, image 2 de 3 Linksys WRT54G Teardown, Remove Top Panel: étape 4, image 3 de 3
    • Now, slide the top plastic panel off and put it aside you now have a clear view of the motherboard.
    • Intel TE28F320 Flash Memory
    • Broadcom BCM4712KPB (I think it’s a modem chip)
    • Admtek ADM6996L Ethernet Controller
    • Activity LEDs
    • Issi 42S16400-6T Random Access Memory (unsure how much)
    • An assortment of other chips I couldn't find.
  5. Linksys WRT54G Teardown, Remove Motherboard: étape 5, image 1 de 3 Linksys WRT54G Teardown, Remove Motherboard: étape 5, image 2 de 3 Linksys WRT54G Teardown, Remove Motherboard: étape 5, image 3 de 3
    • Time to remove the motherboard! Unscrew the single Phillips screw, slide the motherboard and then lift it out.
    • Single Phillips screw
    • Plastic slips holding the motherboard in place.
  6. Linksys WRT54G Teardown, Done!: étape 6, image 1 de 1
    • You're done! Thanks for sticking with me for my first teardown!
    • If you want to reassemble this, just do this guide in reverse order! (assuming you didn't break it like I did)
Reed Crosby
Membre depuis le 12/07/16
4 368 Réputation
1 tutoriel rédigé
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
161 membres
300 tutoriels rédigés
2 commentaires
Happened to get one of these from goodwill recently and wanted to take it apart to take a look. This was really helpful for doing that, deeply appreciate these teardown posts.
Chris Caldwell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 89
Total : 7,528
