Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Toy Microscope, utilisez notre manuel de réparation.
  1. Toy Microscope Teardown, Toy Microscope Teardown: étape 1, image 1 de 3 Toy Microscope Teardown, Toy Microscope Teardown: étape 1, image 2 de 3 Toy Microscope Teardown, Toy Microscope Teardown: étape 1, image 3 de 3
    • The microscope package (that's right, some items were lost and the box suffered)
    • The back of the box with all its items.
    • The useful piece of the microscope package: the microscope (not very surprising...)
  2. Toy Microscope Teardown: étape 2, image 1 de 3 Toy Microscope Teardown: étape 2, image 2 de 3 Toy Microscope Teardown: étape 2, image 3 de 3
    • Now, let's begin the operation: we'll begin with the pedestal. No need for screwdrivers, you just have to pull it.
    • After this, there's a screw. Let's remove it.
    • Once you did it, the battery compartment can be removed.
    • Note: if you want to remove the pedestal completely, you may need to cut the both wires.
    • Note 2: from now on, the microscope will be more difficult to reassemble.
  3. Toy Microscope Teardown: étape 3, image 1 de 3 Toy Microscope Teardown: étape 3, image 2 de 3 Toy Microscope Teardown: étape 3, image 3 de 3
    • Then, this rotative piece is, in a side, a mirror and in the another, a lamp (hence the 1.5x2 batteries in the step 2).
    • To remove it, you need pull a side. The rest will come alone.
    • The picture is a little fuzzy but we can see:
    • The bulb.
    • The support of this rotative piece.
    • The battery.
    • The cover which prevents the bulb to fall.
    • The mirror and the bulb location
  4. Toy Microscope Teardown: étape 4, image 1 de 2 Toy Microscope Teardown: étape 4, image 2 de 2
    • Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw.
  5. Toy Microscope Teardown: étape 5, image 1 de 2 Toy Microscope Teardown: étape 5, image 2 de 2
    • Next step: remove the plate (it's here that you put the item to analyze): 2 Phillips screws.
  6. Toy Microscope Teardown: étape 6, image 1 de 3 Toy Microscope Teardown: étape 6, image 2 de 3 Toy Microscope Teardown: étape 6, image 3 de 3
    • This piece allows you to change the growth. 1 screw.
    • If you turn this piece, the growth will be modified thanks to these magnifying glasses (red circles)
    • To remove them, you need to use a sharp piece (e.g a pen) and press on the 3 holes marked on blue.
  7. Toy Microscope Teardown: étape 7, image 1 de 1
    • You can easily pull off the black part.
  8. Toy Microscope Teardown: étape 8, image 1 de 1
    • After removing the black part (step 6), turn the wheel until you withdraw the lens.
  9. Toy Microscope Teardown: étape 9, image 1 de 2 Toy Microscope Teardown: étape 9, image 2 de 2
    • This mechanical wheel allows you to hang over or hold off the lens in order to improve the clearness.
    • If you like unscrew whatever you find, there are 2 screws.
  10. Toy Microscope Teardown: étape 10, image 1 de 2 Toy Microscope Teardown: étape 10, image 2 de 2
    • Now, let's analyze the lens.
    • You just have to pull the different parts.
  11. Toy Microscope Teardown: étape 11, image 1 de 2 Toy Microscope Teardown: étape 11, image 2 de 2
    • The lens which enlarges the item to analyze from 12 to 18 times.
    • A tube, without magnifiers.
  12. Toy Microscope Teardown: étape 12, image 1 de 1
    • Here, that was the consequences when you lend me a microscope. RIP.
    • In the bottom right corner, you can see the perpetrators of this teardown.
Bob
Membre depuis le 04/17/10
760 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 27
Total : 6,699
