Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Motorola i450 Boost Mobile, utilisez notre manuel de réparation.
  1. Motorola i450 Boost Mobile Teardown, Antenna: étape 1, image 1 de 3 Motorola i450 Boost Mobile Teardown, Antenna: étape 1, image 2 de 3 Motorola i450 Boost Mobile Teardown, Antenna: étape 1, image 3 de 3
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Teardown: étape 2, image 1 de 3 Motorola i450 Boost Mobile Teardown: étape 2, image 2 de 3 Motorola i450 Boost Mobile Teardown: étape 2, image 3 de 3
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
  3. Motorola i450 Boost Mobile Teardown, Back Cover: étape 3, image 1 de 3 Motorola i450 Boost Mobile Teardown, Back Cover: étape 3, image 2 de 3 Motorola i450 Boost Mobile Teardown, Back Cover: étape 3, image 3 de 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  4. Motorola i450 Boost Mobile Teardown, Battery: étape 4, image 1 de 3 Motorola i450 Boost Mobile Teardown, Battery: étape 4, image 2 de 3 Motorola i450 Boost Mobile Teardown, Battery: étape 4, image 3 de 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  5. Motorola i450 Boost Mobile Teardown, SIM Card: étape 5, image 1 de 2 Motorola i450 Boost Mobile Teardown, SIM Card: étape 5, image 2 de 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  6. Motorola i450 Boost Mobile Teardown: étape 6, image 1 de 3 Motorola i450 Boost Mobile Teardown: étape 6, image 2 de 3 Motorola i450 Boost Mobile Teardown: étape 6, image 3 de 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  7. Motorola i450 Boost Mobile Teardown, Circuit Board: étape 7, image 1 de 1
    • Extend the antenna.
  8. Motorola i450 Boost Mobile Teardown: étape 8, image 1 de 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  9. Motorola i450 Boost Mobile Teardown: étape 9, image 1 de 3 Motorola i450 Boost Mobile Teardown: étape 9, image 2 de 3 Motorola i450 Boost Mobile Teardown: étape 9, image 3 de 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  10. Motorola i450 Boost Mobile Teardown, Keypad: étape 10, image 1 de 3 Motorola i450 Boost Mobile Teardown, Keypad: étape 10, image 2 de 3 Motorola i450 Boost Mobile Teardown, Keypad: étape 10, image 3 de 3
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
  11. Motorola i450 Boost Mobile Teardown, Motorola i450 Boost Mobile Teardown: étape 11, image 1 de 1
    • Exploded view of all phone components.
Nathan Heavner
Membre depuis le 10/22/12
3 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 15-2, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,243
