Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Mr. Coffee DW13, utilisez notre manuel de réparation.
  1. Mr. Coffee DW13 Teardown, Taking off the bottom: étape 1, image 1 de 2 Mr. Coffee DW13 Teardown, Taking off the bottom: étape 1, image 2 de 2
    • By unscrewing the bottom of the drip coffee maker we get access to its internals.
  2. Mr. Coffee DW13 Teardown, Taking off the Heater: étape 2, image 1 de 1
    • Taking out the 2 screws shown in the image unlocks the water heater, temperature regulator, and pot heater.
  3. Mr. Coffee DW13 Teardown, Power: étape 3, image 1 de 1
    • The red arrows represent the path of the electricity.
    • The electricity travels from the power cord to the switch where they both connect. When the switched is turned on the power goes from the switch to 2 places.
    • The 1st place it goes is to a giant resistor under the metal pipe that transports the water. This resistor is the pot heater and water heater.
    • The 2nd place the power goes is to a temperature regulator, which makes sure the temperature of the water and the pot don't go above a certain point.
  4. Mr. Coffee DW13 Teardown, How It Works: étape 4, image 1 de 1
    • The way the coffee drip works is water travels through the rubber tubes through a metal pipe getting heated.
    • The water can't travel upward so it gets stuck around the temperature regulator where it boils. Once boiled the steam pushes the remaining water left up the tube into the coffee pot.
    • This process repeats over and over again until the switch closing the circuit opens up again
ThatDoodNate
Membre depuis le 04/15/18
379 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 30
Total : 2,817
