Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Nokia 6108, utilisez notre manuel de réparation.
  1. Nokia 6108 Teardown, Nokia 6108 Teardown: étape 1, image 1 de 1
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Nokia 6108 Teardown: étape 2, image 1 de 2 Nokia 6108 Teardown: étape 2, image 2 de 2
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Nokia 6108 Teardown: étape 3, image 1 de 2 Nokia 6108 Teardown: étape 3, image 2 de 2
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. Nokia 6108 Teardown: étape 4, image 1 de 2 Nokia 6108 Teardown: étape 4, image 2 de 2
    • Remove 5 trox screws that are holding the screen and the touch pad.
  5. Nokia 6108 Teardown: étape 5, image 1 de 2 Nokia 6108 Teardown: étape 5, image 2 de 2
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  6. Nokia 6108 Teardown: étape 6, image 1 de 1
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  7. Nokia 6108 Teardown: étape 7, image 1 de 1
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  8. Nokia 6108 Teardown: étape 8, image 1 de 2 Nokia 6108 Teardown: étape 8, image 2 de 2
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
Membre depuis le 02/19/11
349 Réputation
1 tutoriel rédigé
Un commentaire
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 4,729
