Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Osram Lightify, utilisez notre manuel de réparation.
  1. Osram Lightify Teardown, Osram Lightify Teardown: étape 1, image 1 de 1
    • This is the Osram Lightify. This is a broken unit that does not sync to the app properly. I got a free replacement due to that.
    • Ooh... Shiny! you can see my iPhone 5s in it!
    • No more chit-chat. Time to dig in!
  2. Osram Lightify Teardown: étape 2, image 1 de 2 Osram Lightify Teardown: étape 2, image 2 de 2
    • A mysterious unlabeled button. sadly, not red.
    • The info for the device, Zigbee certified. Zigbee tries to turn all the different wireless control apps and stuff into one app.
    • It almost seems like someone taped over the device's unique ID to control it...
  3. Osram Lightify Teardown: étape 4, image 1 de 3 Osram Lightify Teardown: étape 4, image 2 de 3 Osram Lightify Teardown: étape 4, image 3 de 3
    • Hmmm... No give. maybe not that side.
    • When it goes back in, it gives a nice deafening POP.
    • Finally. now we are getting somewhere.
  4. Osram Lightify Teardown: étape 5, image 1 de 3 Osram Lightify Teardown: étape 5, image 2 de 3 Osram Lightify Teardown: étape 5, image 3 de 3
    • The white thing seems to let light through, but not let you see through to the inside.
    • Seems to just pop right off. This is pretty easy so far!
    • You can now see right through it.
  5. Osram Lightify Teardown: étape 6, image 1 de 2 Osram Lightify Teardown: étape 6, image 2 de 2
    • Its now open!
    • With no option in sight, we keep on prying.
  6. Osram Lightify Teardown: étape 7, image 1 de 3 Osram Lightify Teardown: étape 7, image 2 de 3 Osram Lightify Teardown: étape 7, image 3 de 3
    • Not much to see here...
    • These Appear to be antennas...
    • The only interesting thing so far: Some flash memory, at a whopping 32 megabits the spiflash 25Q32FVSIG . Wow.
    • There has to be something under these plates...
    • Prying was no help. these plates seem to be mounted with... SOLDER
    • Commence desoldering.
  7. Osram Lightify Teardown: étape 9, image 1 de 1
    • After a good amount of prying and a small nick on my thumb, We get back to work.
    • Time for some chip identification!
    • This one appears to be WLAN SoC. its a Marvell 88W8782.
    • The brains of it all, the Micro controller. A Marvell 88MC200
    • And on the smaller side, (what I think is) a Zigbee gateway. a Marvell MZ100
    • Lets dig deeper!
  8. Osram Lightify Teardown: étape 10, image 1 de 3 Osram Lightify Teardown: étape 10, image 2 de 3 Osram Lightify Teardown: étape 10, image 3 de 3
    • Oh goodie! the first screws!
    • there are 2 Torx T9 screws holding in what looks like the power supply.
    • yep, that's the power supply.
  9. Osram Lightify Teardown: étape 11, image 1 de 3 Osram Lightify Teardown: étape 11, image 2 de 3 Osram Lightify Teardown: étape 11, image 3 de 3
    • The prongs that plug into the wall, are not actually soldered to the board, but are just connected by contacting. interesting...
    • There are 2 more Torx T9 screws holding in the cover. most likely after removal of the cover the prongs can also be removed.
    • The 4 screws are all the same, so you can mix and match to your heart's desire!
    • Nope, not individually removable.
  10. Osram Lightify Teardown: étape 12, image 1 de 1
    • I actually highly advise against doing this.
  11. Osram Lightify Teardown: étape 13, image 1 de 3 Osram Lightify Teardown: étape 13, image 2 de 3 Osram Lightify Teardown: étape 13, image 3 de 3
    • On the back we have two long metal sheets.
    • Removal is pretty straightforward.
    • And on the front again, the button slides right out.
  12. Osram Lightify Teardown: étape 14, image 1 de 1
    • I'd give this a 9 out of 10.
    • All screws and tabs.
    • Easily repaired without much knowledge of repair.
    • main board slides right out of the power connections.
    • Tiny bit of adhesive on the logo holding it in place, so it will not securely fit in after removal. although it will still fit snugly and not come out without rough handling. This is an unlikely repair anyway.
Aiden
Membre depuis le 09/19/15
17 429 Réputation
21 tutoriels rédigés
3 commentaires
@oldturkey03 I’ve always knew my soldering skills ;)
Aiden - Réponse
@captainsnowball Looks good. Now, all you have left to do is to tell the world what is under the EMI shields.
oldturkey03 - Réponse
will do tommorow
Aiden -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 3,084
