Outils recommandés dans ce démontage
Introduction
Despite its hyper-loyal fanbase, Pebble returned to Kickstarter for a third time in 2016 to fund their next generation of e-paper smartwatches. Their campaign goals were met, but only 1/3 of the promised products were ever shipped—only the Pebble 2 made it to customers. Then, to all of our disbelief, Pebble was devoured by Fitbit who seems to have forgotten that people might still want smartwatches that last more than 3 days on a charge.
Let's see what Pebble's last smartwatch looks like on the inside, and whether or not you'll be able to swap out parts to keep it ticking for... well, forever, hopefully.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Pebble 2, utilisez notre manuel de réparation.
Ahh, e-paper displays. The best way to make a smartwatch. Pebble always had a real knack for making a great product regardless of specs, but here's what they say is inside: An M4 ARM Cortex processor clocked at 100 MHz
  • Ahh, e-paper displays. The best way to make a smartwatch. Pebble always had a real knack for making a great product regardless of specs, but here's what they say is inside:
    • An M4 ARM Cortex processor clocked at 100 MHz
    • 1.26 inches of low-power, black & white, e-paper goodness behind Corning Gorilla Glass
    • Bluetooth 4.1 (an upgrade from the previous generation's 4.0)
    • A lithium-ion battery big enough to power all this for 7-10 days (depending on whether you sprung for the heart rate model—we didn't)
Ajouter un commentaire
Last year's Pebble Time was an all-around winner in terms of repairability, scoring a 9 out of 10 on iFixit's scale. Let's see if they kept up the good work this year. The first difference we encounter is that this device seems to open from the back instead of the front—we're hoping this doesn't mean the display is married to the glass. With a little help from our purple blow dryer and a pry tool, we get our first look at the insides—so far, so good!
  • Last year's Pebble Time was an all-around winner in terms of repairability, scoring a 9 out of 10 on iFixit's scale. Let's see if they kept up the good work this year.
  • The first difference we encounter is that this device seems to open from the back instead of the front—we're hoping this doesn't mean the display is married to the glass.
  • With a little help from our purple blow dryer and a pry tool, we get our first look at the insides—so far, so good!
We are now face-to-face with the motherboard. We spot two black Philips #0 screws, and one silver Philips #0 screw.
  • We are now face-to-face with the motherboard.
    • We spot two black Philips #0 screws,
    • and one silver Philips #0 screw.
  • These colors indicate different screw lengths, which is helpful for making sure they go back in the correct spot.
After snapping the eccentric rotating mass (ERM) vibration motor out of its housing on the backside of the display,  we can begin to lift up the motherboard... Only to be snagged by some sneaky display cables! As we deftly maneuver a spudger to unclip the two(two?) display cables from the underside of the motherboard, we realize with great sadness that the battery and the vibration motor are both hanging on by a solder.
  • After snapping the eccentric rotating mass (ERM) vibration motor out of its housing on the backside of the display, we can begin to lift up the motherboard...
  • Only to be snagged by some sneaky display cables!
  • As we deftly maneuver a spudger to unclip the two(two?) display cables from the underside of the motherboard, we realize with great sadness that the battery and the vibration motor are both hanging on by a solder.
  • With the display cables free, we can lift out the motherboard and her soldered-on freeloaders.
We're regretting bringing a zoom lens to a macro fight, but here's what we can make out of the front-side ICs:
  • We're regretting bringing a zoom lens to a macro fight, but here's what we can make out of the front-side ICs:
    • That 100 MHz ARM Cortex M4
    • Dialog's SmartBond DA14681 Bluetooth LE SoC
    • A mysterious memory chip, rumored to have 8mb of room to play
    • Pebble's smartstrap data and charging pins,
    • and their accompanying grounding pin
  • We also see here a similar-sized battery to last year's Pebble Time, though in much less friendly packaging.
Which ARM soc is it ? can you see the name of the chip ? is it stm32f411 ?
Nikhil Joshi - Réponse
The far side of this MB only has two notable ICs:
  • The far side of this MB only has two notable ICs:
    • One of Bosch's BMA-series accelerometers
      • Note that we take a hit here from the BMI series in the Pebble Time, losing some cool features like the compass. $99 only goes so far, you know
    • An ambient light sensor
Turning back to the body, we are met with a cold, metal wall. With no more screws in sight, we start pulling and prying, and are met with success! The black & white e-paper display comes out in one piece. We start to feel concerned, however, by the fact that we aren't seeing through the display glass after pulling out the display.
  • Turning back to the body, we are met with a cold, metal wall.
  • With no more screws in sight, we start pulling and prying, and are met with success! The black & white e-paper display comes out in one piece.
  • We start to feel concerned, however, by the fact that we aren't seeing through the display glass after pulling out the display.
Moving past our bamboozlement, we have come to the conclusion that we think Pebble opted for some kind of two-layer e-ink display. Regular e-ink displays use tiny chambers filled with magnetized ink pigments that can be manipulated with an electric charge. Here it seems that Pebble is instead using two separate displays: one black, and one white. Unfortunately for us, this inky black screen marked the end of our mostly adhesive-free teardown.
  • Moving past our bamboozlement, we have come to the conclusion that we think Pebble opted for some kind of two-layer e-ink display.
  • Regular e-ink displays use tiny chambers filled with magnetized ink pigments that can be manipulated with an electric charge. Here it seems that Pebble is instead using two separate displays: one black, and one white.
  • Unfortunately for us, this inky black screen marked the end of our mostly adhesive-free teardown.
  • Even with our trusty purple blow dryer, we couldn't seem to loosen the adhesive enough to pry the last layers out without breaking them.
There's not much left of this watch! Like the company, we are left with a hollow reminder of what was once something great. We try to dismantle the buttons, like last year, but find that they are built in to the chassis. It would have been nice to simply be able to swap out either side and replace the accompanying buttons, but no such luck here.
  • There's not much left of this watch! Like the company, we are left with a hollow reminder of what was once something great.
  • We try to dismantle the buttons, like last year, but find that they are built in to the chassis. It would have been nice to simply be able to swap out either side and replace the accompanying buttons, but no such luck here.
That's it! In a surprising departure from its older sibling, this Pebble 2 turned out to not be very repairable at all. If we had the authority of the iFixit team behind us, we would probably rate this at a 2/10.
  • That's it! In a surprising departure from its older sibling, this Pebble 2 turned out to not be very repairable at all.
  • If we had the authority of the iFixit team behind us, we would probably rate this at a 2/10.
    • Pebble stuck with industry-standard 22 mm watchbands, so you can still swap those out all you like!
    • The motherboard and first part of the screen can be removed fairly easily,
    • but with both the battery and the vibration motor soldered on, there won't be much swapping going on.
    • Since the second half of the screen is glued to the front glass, neither it nor the glass are feasibly replaceable.
    • Button replacements are also a no-go.
  • If you're looking to stay on the Pebble train as long as possible, you might want to pick up a few of these on Amazon while they're still around.
Taylor Dixon
Membre depuis le 30/04/2018
191 Réputation
1 tutoriel rédigé
Bugger! I was hoping to be able to use my eBay non-heartrate buttons on my original Pebble with the busted right-hand buttons…
Looks like that’s not an option. Ah, well, I’ll do without the pulse measurements until this one eventually dies and I see whether anyone else has come up with a smartwatch with an always-on display.
Ian Mackereth - Réponse
Voir les statistiques:
Dernières 24 heures : 14
7 derniers jours : 80
30 derniers jours : 447
Total : 890
