Outils recommandés dans ce démontage
Introduction
This guide provides step-by-step instructions on disassembling the Picstart Plus development programmer.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Picstart Plus Development Programmer, utilisez notre manuel de réparation.
Remove 4 Phillips screws located on the back side of the holding plate. After the screws are removed, remove the case of the development programmer. Carefully take out the circuit board with component side facing up. Put the case aside.
  • Remove 4 Phillips screws located on the back side of the holding plate.
  • After the screws are removed, remove the case of the development programmer.
  • Carefully take out the circuit board with component side facing up. Put the case aside.
Ajouter un commentaire
Disconnect the microcontroller module from the main board using a spudger or a similar tool. Set the microcontroller module aside.
  • Disconnect the microcontroller module from the main board using a spudger or a similar tool.
  • Set the microcontroller module aside.
Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder Remove the cover of the IC holder.
  • Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
  • Remove the cover of the IC holder.
Remove the IC holder lever along with the small metal plate that covers the lever. Set the lever and the lever cover aside.
  • Remove the IC holder lever along with the small metal plate that covers the lever.
  • Set the lever and the lever cover aside.
Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
  • Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
  • All the extracted components are shown in the picture.
Brad
Membre depuis le 17/11/2013
597 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 1,352
