Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Rubik's Cube, utilisez notre manuel de réparation.
Turn the top row so that each corner is roughly halfway between the sides Push the pieces up until they pop out of the cube, then, slide the rest out Repeat this process until you clear the level
  • Turn the top row so that each corner is roughly halfway between the sides
  • Push the pieces up until they pop out of the cube, then, slide the rest out
  • Repeat this process until you clear the level
Ajouter un commentaire
You should be able to just directly pull out the rest of the blocks, like so And there you have it!
  • You should be able to just directly pull out the rest of the blocks, like so
  • And there you have it!
  • You'll have the center piece, with the six centers of the six sides, the turning mechanism
To reassemble, snap all the pieces back into place, and try not to rotate the faces. It helps to start with the middle pieces first
  • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
  • It helps to start with the middle pieces first
  • Don't be afraid to use force!
  • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
  • Again- don't be afraid to use force!
rab777hp
Membre depuis le 17/11/2009
20 299 Réputation
7 tutoriels rédigés
Équipe
OPEN Membre de l'équipe OPEN
Community
74 membres
15 tutoriels rédigés
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Réponse
lol don’t blame you, can’t stand the thing
Luke Legg -
Voir les statistiques:
Dernières 24 heures : 13
7 derniers jours : 57
30 derniers jours : 164
Total : 17,650
