Outils recommandés dans ce démontage
Introduction
The Teardown is pretty much the same as other Samsung Slider phones
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Intensity, utilisez notre manuel de réparation.
Remove the back cover and battery
  • Remove the back cover and battery
Ajouter un commentaire
Remove the 8 screw that hold the back cover down.
  • Remove the 8 screw that hold the back cover down.
  • Carefully pry back piece off
  • Start at the bottom and work toward the top.
Use the ipod opening tool to disconnect the Connector
  • Use the ipod opening tool to disconnect the Connector
Carefully remove the main board Make sure to not tear the microphone cable, pry it from the phone carefully
  • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
Remove the 6 screws Pry to ribbon cable assembly loose from the slider
  • Remove the 6 screws
  • Pry to ribbon cable assembly loose from the slider
  • Its glued on the left and right side
Remove the 4 screw the holds the slider to the phone assembly
  • Remove the 4 screw the holds the slider to the phone assembly
  • one of the screws will be behind the hinge
  • Carefully pry slider assembly loose from display assembly
Remove the tape and pop the connectors and pull all the ribbon cables loose Carefully pry the speaker loose from the case. Carefully pry the speaker loose from the case.
  • Remove the tape and pop the connectors and pull all the ribbon cables loose
  • Carefully pry the speaker loose from the case.
Carefully work the keyboard loose from the display assembly
  • Carefully work the keyboard loose from the display assembly
  • There are a couple fragile clips that hold it in place
LCD comes out pretty easily Pry it from the bottom and work up the sides to release it if stuck
  • LCD comes out pretty easily
  • Pry it from the bottom and work up the sides to release it if stuck
  • The glass can be removed with a little heat from a heat gun or blow dryer
  • Pry it out from the outside edges working around carefully
David
Membre depuis le 10/08/2011
110 Réputation
1 tutoriel rédigé
Équipe
West Georgia Technology Membre de l'équipe West Georgia Technology
Business
1 membre
1 tutoriel rédigé
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 22
Total : 3,651
