Alright. This guide is a teardown to show the safest and easiest way to take apart your genesis.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sega Genesis II, utilisez notre manuel de réparation.
Carefully lift the top off of the console.
It should come off relatively easy
If it doesn't, ensure that all four screws are removed
Remove the six, gold, 8mm screws and the three, black, 8mm screws holding down the EM shield
After removing the screws, the shield will come off very easily.
Remove the two 17mm black screws on the left and right side of the PIN to release the circuit board from the bottom EM shield.
After the screws are releases, the circuit board can easily be removed from the console.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
