Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sony DVD Player, utilisez notre manuel de réparation.
  1. Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: étape 1, image 1 de 2 Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: étape 1, image 2 de 2
    • This is the device we will be tearing down.
  2. Sony DVD VHS Player  Teardown: étape 2, image 1 de 1
    • First, you need to remove the three black screws on the back.
  3. Sony DVD VHS Player  Teardown: étape 3, image 1 de 1
    • Now, you need to remove the cover by lifting it up like you would the cover of a shoe box, but it will come off. But before you do that you will need to unhook it by unclipping the clips on the back.
  4. Sony DVD VHS Player  Teardown: étape 4, image 1 de 1
    • You must now remove the silver bar attached to the VHS receptor.
  5. Sony DVD VHS Player  Teardown: étape 5, image 1 de 1
    • Once you have removed that silver bar you will now unscrew and remove the DVD Disc tray.
  6. Sony DVD VHS Player  Teardown: étape 6, image 1 de 2 Sony DVD VHS Player  Teardown: étape 6, image 2 de 2
    • Now that the DVD tray is out of the way, you can remove the smaller motherboard, the green one to specify easier. You will do this by removing the screws that hold it in.
  7. Sony DVD VHS Player  Teardown: étape 7, image 1 de 3 Sony DVD VHS Player  Teardown: étape 7, image 2 de 3 Sony DVD VHS Player  Teardown: étape 7, image 3 de 3
    • Now you can unscrew the VHS receptor and remove that to be able to access, unscrew and remove the final piece, the large motherboard.
  8. Sony DVD VHS Player  Teardown: étape 8, image 1 de 3 Sony DVD VHS Player  Teardown: étape 8, image 2 de 3 Sony DVD VHS Player  Teardown: étape 8, image 3 de 3
    • Now, you will remove the large, orange motherboard. You will need to unscrew it and pop it out. You MUST be careful as this piece is extremely fragile, and the smallest fracture or damage will cause it to no longer work.
Blake Sullivan
Membre depuis le 04/20/18
185 Réputation
1 tutoriel rédigé
Un commentaire
Wish I could repair the DVD no luck in finding part the part
Joseph Pigott - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 2,332
