Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sony MZ-R700 Minidisc, utilisez notre manuel de réparation.
  1. Sony MZ-R700 Minidisc Teardown, Teardown: étape 1, image 1 de 3 Sony MZ-R700 Minidisc Teardown, Teardown: étape 1, image 2 de 3 Sony MZ-R700 Minidisc Teardown, Teardown: étape 1, image 3 de 3
    • Start by removing the 8 very small screws on both sides of the unit. The front door will still be connected via the latch.
  2. Sony MZ-R700 Minidisc Teardown: étape 2, image 1 de 1
    • Next, remove 7 screws on the inside front panel. This will disconnect the frontal logic board with LCD display and remove the front panel.
  3. Sony MZ-R700 Minidisc Teardown: étape 3, image 1 de 2 Sony MZ-R700 Minidisc Teardown: étape 3, image 2 de 2
    • The front panel may now be removed. Next, remove one screw on the inside front panel.
  4. Sony MZ-R700 Minidisc Teardown: étape 4, image 1 de 1
    • Carefully remove the unit from the outside casing. Use a spudger or a small screwdriver to wedge it out all along the sides. The plastic casing is quite malleable and has some give to it, so don't be overly gentle.
  5. Sony MZ-R700 Minidisc Teardown: étape 5, image 1 de 2 Sony MZ-R700 Minidisc Teardown: étape 5, image 2 de 2
    • Remove 2 screws under the battery case. There are 6 more screws on the logic board that need to be removed, 3 on the right-hand side and 2 on the left with the final one hidden under the battery case.
  6. Sony MZ-R700 Minidisc Teardown: étape 6, image 1 de 3 Sony MZ-R700 Minidisc Teardown: étape 6, image 2 de 3 Sony MZ-R700 Minidisc Teardown: étape 6, image 3 de 3
    • Next, remove the front panel from the main part of the unit. The ribbon cable connects the two. To remove, gently pull out the dark brown connector from both sides of the beige holder. This will release the ribbon cable which can then be pulled out and separated. There are three in total, two on the outside, one under the battery case and one on the lower part of the unit. The third one is on the inside of the unit.
  7. Sony MZ-R700 Minidisc Teardown: étape 7, image 1 de 1
    • Remove the remaining 10 visible screws which connect the laser eye and related mechanism. Start from the bottom up as they will release various latches and connectors from the unit.
  8. Sony MZ-R700 Minidisc Teardown: étape 8, image 1 de 3 Sony MZ-R700 Minidisc Teardown: étape 8, image 2 de 3 Sony MZ-R700 Minidisc Teardown: étape 8, image 3 de 3
    • Gently pry the door away from the metal enclosure. Next, remove the bar on the side of the enclosure. Pry a flathead screwdriver between them and gently remove it. Finally, remove the black gear (above the green one, removed here) which will reveal one more, tiny screw that needs to be removed. At this point you may remove any remaining latches connected to the unit. Simply pry with a small flathead screwdriver and remove them.
  9. Sony MZ-R700 Minidisc Teardown: étape 9, image 1 de 1
    • Congratulations, you have successfully completed the Sony MZ-R700 Minidisc teardown!
refo
Membre depuis le 10/23/09
51 Réputation
1 tutoriel rédigé
4 commentaires
Why would you do that?
Have you put it back together?
Does it work?
Richard Harris - Réponse
Thank you! Used this guide to open my R700 :)
Bert Bré (The Milkman) - Réponse
Richard Harris: Probably so that you can replace one of those parts in the event one of them is broken
marc crowther - Réponse
Fine. However, the biggest problem with Sony MD players/recorders is the unavailability of the dedicated rechargeable batteries they require for use as independent units.
Andrew Russell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 64
Total : 22,235
