Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre PlayStation, utilisez notre manuel de réparation.
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: étape 1, image 1 de 2 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: étape 1, image 2 de 2
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: étape 2, image 1 de 1
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: étape 3, image 1 de 1
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: étape 4, image 1 de 2 Sony PlayStation SCPH-9002 Teardown: étape 4, image 2 de 2
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: étape 5, image 1 de 1
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: étape 6, image 1 de 1
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: étape 7, image 1 de 2 Sony PlayStation SCPH-9002 Teardown: étape 7, image 2 de 2
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: étape 8, image 1 de 1
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: étape 9, image 1 de 1
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: étape 10, image 1 de 1
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
Membre depuis le 05/06/10
182 Réputation
1 tutoriel rédigé
Un commentaire
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 26
30 derniers jours : 135
Total : 27,804
