Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sony VAIO PCG-61411L, utilisez notre manuel de réparation.
  1. Sony VAIO PCG-61411L Teardown, Sony VAIO PCG-61411L Teardown: étape 1, image 1 de 3 Sony VAIO PCG-61411L Teardown, Sony VAIO PCG-61411L Teardown: étape 1, image 2 de 3 Sony VAIO PCG-61411L Teardown, Sony VAIO PCG-61411L Teardown: étape 1, image 3 de 3
    • In this guide I'll be doing a full disassembly of a Sony VAIO PCG-61411L laptop. My hope is that you will find some helpful information here and possibly save some money! lets get started!
  2. Sony VAIO PCG-61411L Teardown: étape 2, image 1 de 1
    • First unlock the battery with the sliding locks (marked with orange indicators), and lift battery up and out.
    • When working with laptops always remove batteries or charging cords first, if possible, as powering the unit while touching the components can be fatal to you or the device!
  3. Sony VAIO PCG-61411L Teardown: étape 3, image 1 de 3 Sony VAIO PCG-61411L Teardown: étape 3, image 2 de 3 Sony VAIO PCG-61411L Teardown: étape 3, image 3 de 3
    • Next loosen the hard drive cover screws as shown (marked with red indicators picture 1) And remove the hard drive bay cover.
    • Remove screws from indicated areas (picture 2).
    • place screws in a safe location or container (I use powerade bottle caps to separate screws from different parts of a project)
    • Use the tab (indicated in picture 3) to pull the hard drive to the side and lift it free.
  4. Sony VAIO PCG-61411L Teardown: étape 4, image 1 de 3 Sony VAIO PCG-61411L Teardown: étape 4, image 2 de 3 Sony VAIO PCG-61411L Teardown: étape 4, image 3 de 3
    • Loosen the screw marked (indicated in the red circle) and pull the RAM bay cover free. (the cover has plastic tabs on the sides and may take a few tries to free it.)
    • push the metal tabs on either side of the RAM chips, making them lean up slightly, and pull both chips free
  5. Sony VAIO PCG-61411L Teardown: étape 5, image 1 de 2 Sony VAIO PCG-61411L Teardown: étape 5, image 2 de 2
    • Remove 2 screws (indicated in first picture).
    • Pull CD drive from the laptop.
  6. Sony VAIO PCG-61411L Teardown: étape 6, image 1 de 3 Sony VAIO PCG-61411L Teardown: étape 6, image 2 de 3 Sony VAIO PCG-61411L Teardown: étape 6, image 3 de 3
    • Remove the 15 screws indicated by red circles setting them aside in their own container
    • Remove the 3 screws indicated by yellow circles setting them aside in their own container as well
    • Pull up on tab in the RAM bay as indicated. (the black pull tab may detach, don't worry it will not affect performance)
    • Gently begin to pull the bottom casing free
  7. Sony VAIO PCG-61411L Teardown: étape 7, image 1 de 2 Sony VAIO PCG-61411L Teardown: étape 7, image 2 de 2
    • Begin unplugging cords from the motherboard in designated locations
geekinthebasement
Membre depuis le 10/21/12
181 Réputation
1 tutoriel rédigé
Équipe
Geek in the basement Membre de l'équipe Geek in the basement
Business
1 membre
1 tutoriel rédigé
2 commentaires
I would have to say a partial disassembly, unless I'm missing pages somewhere?
Colm - Réponse
As a matter of fact there are 20 (not 15) small black screws (in addition to the 3 silver ones) that hold down the bottom casing. Also, I could not pull the tab in the RAM bay, but was able to rotate the bottom casing around that cable to access the fan, which needed cleaning.
xjekeli - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 34
Total : 20,552
