Outils recommandés dans ce démontage
Introduction
This guide will walk you through the steps to completely disassemble a Sprint Airave.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sprint Airave SCS-26UC2, utilisez notre manuel de réparation.
Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module.
  • Remove the external antenna, GPS cover, and GPS module.
Ajouter un commentaire
Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
  • Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
Locate and remove the four Phillips screws
  • Locate and remove the four Phillips screws
With the cover removed you now have access to the circuit board.
  • With the cover removed you now have access to the circuit board.
Using an 8mm socket you can remove the antenna pigtail.
  • Using an 8mm socket you can remove the antenna pigtail.
Release the clip indicate to remove the circuit board.
  • Release the clip indicate to remove the circuit board.
Here is the circuit board fully removed. Here is the circuit board fully removed.
  • Here is the circuit board fully removed.
Erik Leonard
Membre depuis le 11/06/2011
164 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 2,988
