Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Tungsten E, utilisez notre manuel de réparation.
  1. Tungsten E Teardown, Tungsten E Teardown: étape 1, image 1 de 3 Tungsten E Teardown, Tungsten E Teardown: étape 1, image 2 de 3 Tungsten E Teardown, Tungsten E Teardown: étape 1, image 3 de 3
    • There are quite a few parts to keep track of. While many of these parts will easily snap back into place, there are several that result in "oops" and will probably make your Palm useless. Proceed with caution!!
  2. Tungsten E Teardown: étape 2, image 1 de 3 Tungsten E Teardown: étape 2, image 2 de 3 Tungsten E Teardown: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    T6 Torx Screwdriver
    $9.99
    J'achète
    • There are four T6 screws on the backside of the Palm which must be removed for access into the inner workings. The tool is a T6 screwdriver, available in the parts store. Either purchased separately as the T6 Torx screwdriver or as a kit in the 20 Piece Bit Driver Kit.
  3. Tungsten E Teardown: étape 3, image 1 de 3 Tungsten E Teardown: étape 3, image 2 de 3 Tungsten E Teardown: étape 3, image 3 de 3
    • To detach the back cover use your fingernail to gently pry the top edge. It will come apart like a clamshell. Be careful for the red and black cord attaching the two pieces. This is the battery cable. Use your fingers to unclip the cable connector from the circuit board. The battery is glued to the back cover.
  4. Tungsten E Teardown: étape 4, image 1 de 3 Tungsten E Teardown: étape 4, image 2 de 3 Tungsten E Teardown: étape 4, image 3 de 3
    • The back panel has been removed, note the small red rectangle which highlights the battery terminal. The circuit board and the screen can now be separated. They are connected by the brownish flat cable which is clipped into the clippydohah on the screen. Unclip and proceed.
  5. Tungsten E Teardown: étape 5, image 1 de 1
    • Seen in this photo is the clear keypad. You might want to clean this off if you've spilled a soda on it or otherwise got it sticky.
  6. Tungsten E Teardown: étape 6, image 1 de 2 Tungsten E Teardown: étape 6, image 2 de 2
    • The screen is sandwiched in a metal case. It didn't seem clipped together but it was a snug fit. I pushed on the circuit board through the cutouts in the metal to pry the pieces apart.
  7. Tungsten E Teardown: étape 7, image 1 de 1
    • The touchscreen part of the screen assembly is glued to the LCD panel. It will peel off. Notice the cable connecting the two. It pulled out and I couldn't figure out how to make it stay again. Pulling out is NOT a good method!!!
  8. Tungsten E Teardown: étape 8, image 1 de 3 Tungsten E Teardown: étape 8, image 2 de 3 Tungsten E Teardown: étape 8, image 3 de 3
    • There are about 6 layers which make up the screen. A clear hard plastic, a shiny flimsy opaque one, a polorizing film, and a really nifty one that either magnifies or reflects depending on the lighting.
  9. Tungsten E Teardown: étape 9, image 1 de 3 Tungsten E Teardown: étape 9, image 2 de 3 Tungsten E Teardown: étape 9, image 3 de 3
    • fun with the films
  10. Tungsten E Teardown: étape 10, image 1 de 3 Tungsten E Teardown: étape 10, image 2 de 3 Tungsten E Teardown: étape 10, image 3 de 3
    • more fun with the films and a shot of the screen.
  11. Tungsten E Teardown: étape 11, image 1 de 1
    • The final discombobulationess of fully non-functioning bits and pieces. The sum of all its parts was never as purdy. To the recycle bin. Bye bye!!
MMiller8846
35 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 9,299
