Outils recommandés dans ce démontage
Introduction
This guide will help you to completely disassemble your phone in order to perform other repairs.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Uniden EXP 371, utilisez notre manuel de réparation.
Uniden EXP371 900 MHz Cordless Phone.
  • Uniden EXP371 900 MHz Cordless Phone.
  • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
Ajouter un commentaire
Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone. Next remove the battery by pulling on the connector.
  • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
  • Next remove the battery by pulling on the connector.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver. Now remove the top portion of the case from the bottom.  This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
  • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
  • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
  • Once you have removed the five screws you may lift the motherboard off of the front case.
  • At this point you may also remove the dial pad. It simply lifts off.
  • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
  • The whole phone is now disassembled at this point.
Tim Reimer
Membre depuis le 19/06/2010
164 Réputation
3 tutoriels rédigés
this guide is poorly written, please delete or improve it.
Walker Quine - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 4,323
