Outils recommandés dans ce démontage
Introduction
This teardown will show you how to get inside your Xbox 360 S to fix what you need to.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Xbox 360 S, utilisez notre manuel de réparation.
Slide latch back and pull up to take the part of the side cover off.
  • Slide latch back and pull up to take the part of the side cover off.
Ajouter un commentaire
Take a flat head screwdriver and pull up on the two ends of the side cover.
  • Take a flat head screwdriver and pull up on the two ends of the side cover.
It would be a good idea to take out your hard drive so gently pull it out and set it aside.
  • It would be a good idea to take out your hard drive so gently pull it out and set it aside.
Take your flat head screwdriver and lift up on every hole like the ones circled in the picture until it comes off.
  • Take your flat head screwdriver and lift up on every hole like the ones circled in the picture until it comes off.
To take off the frame, take a flat head screwdriver and pull of the latches until it comes off.
  • To take off the frame, take a flat head screwdriver and pull of the latches until it comes off.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Take your flat head screwdriver and place in one of the cracks of the side cover on the other side and pull up to take it off.
  • Take your flat head screwdriver and place in one of the cracks of the side cover on the other side and pull up to take it off.
Take your flat head screwdriver and place it in the holes like the ones in the picture until the piece comes off.
  • Take your flat head screwdriver and place it in the holes like the ones in the picture until the piece comes off.
Take a T10 Torque's screwdriver and screw off your network chip so you don't ruin it.
  • Take a T10 Torque's screwdriver and screw off your network chip so you don't ruin it.
Take your flat head screwdriver and unlatch the two latches and then place a different screwdriver through the latch so it doesn't latch.
  • Take your flat head screwdriver and unlatch the two latches and then place a different screwdriver through the latch so it doesn't latch.
On the other side, take your flat head screwdriver and unlatch the latch. There is a harder latch farther inside so you have to stick the screwdriver far down and try to find it by feeling around. It helps to push both sides of your Xbox security sticker.
  • On the other side, take your flat head screwdriver and unlatch the latch. There is a harder latch farther inside so you have to stick the screwdriver far down and try to find it by feeling around. It helps to push both sides of your Xbox security sticker.
Use your T10 Torque screwdriver and take out the five black screws that are shown in the picture. Use your T10 Torque screwdriver and take out the five black screws that are shown in the picture.
  • Use your T10 Torque screwdriver and take out the five black screws that are shown in the picture.
Take your front cover with your home and eject button and lay it down in front of the console. The front cover is connected to a power source by the home button. Be very careful to pull it over and then out so you don't break it. Take your front cover with your home and eject button and lay it down in front of the console. The front cover is connected to a power source by the home button. Be very careful to pull it over and then out so you don't break it. Take your front cover with your home and eject button and lay it down in front of the console. The front cover is connected to a power source by the home button. Be very careful to pull it over and then out so you don't break it.
  • Take your front cover with your home and eject button and lay it down in front of the console. The front cover is connected to a power source by the home button. Be very careful to pull it over and then out so you don't break it.
This is what you will see when you are done with all the previous steps. For other teardowns like the disc tray or power source, look at ifixit.com to get the best on how to teardown something.
  • This is what you will see when you are done with all the previous steps. For other teardowns like the disc tray or power source, look at ifixit.com to get the best on how to teardown something.
Julian Gonzalez
Membre depuis le 19/04/2018
51 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 22
7 derniers jours : 120
30 derniers jours : 504
Total : 624
